If it's an outboard one, you just wire the channels you want to switch, say main L/R to the switch input, and then from the outputs you wire up as many speakers as you want/can be supported by the switcher. Models vary in price and power supported and number of speakers supported. If you want to add an internal switch, someone else will have to do the honours as I don't know enough about that.
