Can anyone help with this Windows installation problem?
Discussion in 'Archived Threads 2001-2004' started by Philip Hamm, Oct 21, 2001.
  1. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    I have a second hand Pentium III Compaq Deskpro that I'm trying to installe Windows Me on. I have the Win98SE boot CD and the WinMe upgrade CD. I also have Windows NT 4.0 on a bookshelf if that is a better option (Does Win NT 4.0 support USB?).
    I have partitioned the 10 Mb drive and formatted it using the Win98SE startup CD. However, when I try to install Win98SE or WinMe I get the message "Standard Mode: Fault outside of MS-DOS Extender" followed by a register dump. The system then tells me that COMMAND.COM is invalid and prompts me for the location for the valid command.com.
    The computer has no model number at all whatsoever, which is frustrating to no end. It simply is identified as a "Deskpro" (I hate Compaqs - I had a lot of trouble with some Compaq machines at a former job). There is a number on the back that says "Series PD1006" and on the top it has a sticker that says "DPENM P600/10/128/NTCUS).
    I have reason to believe that despite the fact that this computer has a sticker on the front that reads "Designed for Microsoft Windows NT / Windows 98" that it may have been specifically designed for NT.
    Compaq's tech support web site has been unhelpful and I have absolutely no documentation at all whatsoever. My next step is to try to install my Windows NT 4.0 Operating System. I don't know how that will go.
    Any tips?????? [​IMG]
    Philip Hamm
    AIM: PhilBiker
    [Edited last by Philip Hamm on October 21, 2001 at 08:41 PM]
  2. ThucN
    ThucN Agent
    Jan 17, 2001
    34
  3. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    Double the partition info by running fdisk to make sure you have set the primary DOS partition and that it is active. If so, format harddrive using 98SE boot disk. After formatting, install 98SE and then change to ME.
    equipment list
  4. Shayne Lebrun
    Shayne Lebrun Screenwriter
    Jun 17, 1999
    1,086
    I don't know about the more modern compaqs, but they are VERY fucked up machines. Some of the desktop machines I used from compaq at a previous job, the frickin BIOS was installed on a very small partition on the hard drive. Fdisked it for Linux, and the machine wouldn't boot. Ooops.
  5. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    I hope this is not another Compaq horror story...best of luck Phil.
    http://www.hometheaterforum.com/bbs/equipment/28687.html
  6. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    I'd imagine that if the BIOS was indeed on the HD then he wouldn't be getting as far as he is with the installation. Compaq are a law unto themselves though, so anything could happen.
  7. Philip Hamm
    Jan 23, 1999
    6,873
    2
    I -may- be able to dig up some boot OS/2 diskettes and run FDISK using that. I used the Win98SE boot CD FDISK to partition the entire 10Gb boot disk as one large partition. I have an old copy of Partition Magic laying around also. I hate hate hate Compaq desktops. Thanks for the tips, but nothing new here. [​IMG]
    Philip Hamm
    AIM: PhilBiker
  8. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
  9. AndyVX
    AndyVX Supporting Actor
    Aug 2, 2000
    804
    Yikes! Compaq's are rotten little machinces! I personally wouldn't spend a dime on them.
    Well, my suggestions would basically be the same as everyone else's here. One thing I wanted to add though is if you get the computer working, don't install WinME! Just stay with Win98SE.
    Andrew
    ICQ# - 119869807
  10. Philip Hamm
    Jan 23, 1999
    6,873
    2
    Why not install WinME? I've been using it since it came out without any problems. I've heard people say "avoid Me!" since it came out, but I've heard that with every version of Windows since 3.1.
    Philip Hamm
    AIM: PhilBiker
  11. Richard Cooper
    Richard Cooper Stunt Coordinator
    Mar 21, 2001
    132
    Hmm, this reminds me a little of a problme I had once. Are you booting from the install CD or a boot disk? If you have a boot disk which asks you which type of CD drive you have (Sony, Goldstar etc.) I found that it didn't matter which make I had, Sony would be the only one to work. If you're booting from the CD, have you a startup disk which you can load CD drivers from instead?
    As for the criticism of ME, I'm going to disagree. It's fine for me [​IMG]
  12. Philip Hamm
    Jan 23, 1999
    6,873
    2
    I think this computer is totally f**ked.
    Windows NT 4.0 Blue Screens on boot / installation disk 2. If I partition it in 98SE it blows up the WinMe and Win98 installations. I am going to email Compaq and see if they can help. I hate Compaq desktops. It looks like a new motherboard for the fine Pentium III 600 may be in order.
    Philip Hamm
    AIM: PhilBiker
  13. Jesse Leonard
    Jesse Leonard Second Unit
    Jun 8, 2000
    430
    Philip,
    Just making sure........., you did format the drive after using FDISk, didn't you?
  14. John_Bonner
    John_Bonner Supporting Actor
    Oct 25, 2000
    664
    Philip,
  15. Mike Voigt
    Mike Voigt Supporting Actor
    Sep 30, 1997
    799
    IF you don't care for the data on the HD, try the following:
    1. Start computer, go into hardware setup (usually F8, or DEL key, or something).
    2. Set it to boot from CD first, then floppy, then HD.
    3. Save the setup.
    4. Use the Win98SE boot CD to set up the HD first (partitions), then proceed to install.
    5. Use Me Upgrade to set up for that.
    See if that helps. As for hating Compaq's, you can add me to that list. A Compaq was the machine that convinced me to build my own [​IMG]
    Mike
  16. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    If your installer screams when it tries to run the MS-DOS extender, most likely you have a memory problem. One of the classic symptoms of bad memory is when the machine runs fairly ok in DOS mode without trying to use extended memory, but when accessing the extended memory during an OS install it chokes.
    Try the install again with some other memory chips. If you have several in the machine, remove some and try installs with different chips.
    There is software out there that runs memory tests. Try here:
    http://www.nu2.nu/utils/
    That is the webpage of a guy who has a very nice how-to on creating bootable CD-ROM's among other things. In his utils directory there is a RAM tester for the PC; just boot the PC from a clean boot floppy (ie one that doesn't load any memory managers etc) and try that one. Haven't tested it, but it might tell you if your memory is bad.
    Otherwise just test with other chips.
    /Kimmo
