Ruben M
Grip
- Jan 29, 2004
I HAVE A QUESTION FOR WHOEVER CAN ANSWER. I'M THINKING ON BUYING A PROJECTOR.
IS THE SANYO PLV-Z2 A GOOD CHOICE FOR DVD USE ONLY GIVEN THAT DVD WORKS AT 480 LINES? WOULD IT BE A PROBLEM OR A WASTE KNOWING THAT THE PLV-Z2 HAS A RESOLUTION OF 1280 X 720?
OR SHOULD I BUY THE DLP AND LOWER RESOLUTION PROJECTORS LIKE NEC LT240K OR THE MITSUBISHI XD300U, WITH A RESOLUTION OF 1024 X 768 FOR 4:3 AND 1024 X 576 FOR 16:9 (BUT HIGHER CONTRAST AND LUMEN OUTPUT)?
IS THERE A BIG DIFERENCE BETWEEN THE DLP (1024 X 576) AND LCD (1280 X 720)?.....
I GUESS I HAD MORE THAN ONE QUESTION.....:b
