Jim
- Oct 4, 1998
I posted a message on another TiVo forum regarding some slight burn-in associated with continued use of the TiVo screens, since they all share a white border around 3/4 of the screen. This is on my Sony RPTV, using TiVo for over 18 months now.
I think TiVO is great, but I am hoping to get TiVo Inc. to look into changing those borders so that this can be minimized in the future.
I'm posting here, since one of the people over there suggested sending a white signal as a "cure" -- here's an excerpt of that reply:
You can unburn your CRT if the damage isn't extensive.
Professional CRT video walls actually display white for 15 minutes after every power-up to make sure burn-in isn't visible on the CRT cubes. The same idea works for televisions... if you're starting to see CRT burn-in, send a pure white (100%) full-screen still video image to your TV for a little while (15 mins or so), then go back to watching TV. Rinse and repeat until the burn-in isn't visible anymore, usually 6-10 applications. Once a day is fine, twice a day won't hurt.
Works most of the time, in non-severe burn-in cases.
Since you guys are the experts on this sort of thing, is this something that should really be done? Am I wearing the tubes out more by doing this, effetively doing more harm than good in the long-term?
Thanks.
Jim
Thanks.
Jim
