Building a new PC any burn-in programs out there for free?
Discussion in 'Archived Threads 2001-2004' started by Gordon Moore, Oct 11, 2001.
  1. Gordon Moore
    Gordon Moore Second Unit
    Nov 1, 2000
    340
    As the subject line states. Burn-in is still necessary, isn't it? It's been a while since I've upgraded. (Last one in '97);
  2. Camp
    Camp Cinematographer
    Dec 3, 1999
    2,301
  3. Iain Lambert
    Iain Lambert Screenwriter
    Jun 7, 1999
    1,345
    3D Mark 2001 is highly recommended for testing stability; stick it on loop mode and run for a few hours. If that doesn't cause you to hit any possible memory, driver or heating problems then I doubt anything will.
  4. Neil T
    Neil T Auditioning
    Jan 28, 2000
    6
    I have to say I think testing and burn-in are two separate issues. Testing a new system is always a good idea but burn-in is unnecessary and wrong in my opinion. Component failure is often linked to thermal changes, the heating up ang cooling down of components. For this reason I would suggest that normal or sporadic (power up/down) of a new system will probably help it "settle down" more quickly.
    Neil.
    The only bad opinion is no opinion.
  5. Gordon Moore
    Nov 1, 2000
    340
    Thanks for the opinions. While I'm not out to crash/damage my system, I do want to ensure stability. Since I'm putting together the system with mostly OEM parts (to keep cost down...but only 30 day - 1 year warranties), I want to make sure that it's up to the task. That being said, when I flick the power switch and I get to the BIOS screen, I'll be pretty happy. (it is only a new motherboard and CPU and memory but the most critical components so I want to ensure they work).
