Michael_UK
- Jun 28, 2001
Hi everybody, I am newish to home audio, but I am very good at car audio and I had the Idea of having a go at making a subwoofer box for an old car sub to use in my room for a bit of bass, can any one help me with the box design because I have tried WinISDWinSPK and have not had much luck getting a box that plays down to 20 ish. (I think the sub woofer driver is not very good low down)
here are the Paramiters for the sub.
Technical datasheet
Impedance (Z) 4 Ohm
Frequency range 35–3,000 Hz
Free air resonance (fs) 35 Hz
Crossover frequency (12 dB/oct.) (fmax) 2,000 Hz
Peak music power 450 W
Power rating 150 WRMS
SPL (1 W/1 m) 93 dB
Cms suspension compliance 0.45 mm/N
Mms moving mass 44 g
Qms mech. Q factor 3.84
Qes electrical Q factor 1.16
Qts total Q factor 0.89
VAS compl. equiv. vol. 180 l
RDC DC resistance (Re) 3.7 Ohm
Voice coil ind.(1kHz,Le) 0.4 mH
Voice coil diameter 39 mm
Voice coil former aluminium
Air gap height 5 mm
Force factor WxL 5.6 Tm
Eff. cone area 531 cm²
Magnet dioameter 125 mm
Magnet weight 30 oz.
Mounting cutout ø 282 mm
Mounting depth 130 mm
Dimensions ø 305 mm
Weight 2.4 kg
Am I wasting my time and materials with build a box for this sub (size of box does not matter e.g. 1-8 CF is possible by me.)
I would like to have a box that plays down to abot 25 hz or lower if possable.
Can anyone help me???
Technical datasheet
Impedance (Z) 4 Ohm
SPL (1 W/1 m) 93 dB
Air gap height 5 mm
Dimensions ø 305 mm
Weight 2.4 kg
