ChristianT
Grip
- Jul 31, 2001
First I am going to build a Sonosub (which I hope to rough finish today). I am not using any 1503 Dumax measurements other than xmax. The rest of the measurements I am using come from the BPD site. For example, what do the BPD Cms and Mms measurements correspond to in Unibox? This question applies to other software like WinISD. I am having trouble matching BPD measurements to measuremets in the software. Do you have any recommendatios for the tuning point? I have 16" diameter sonotube, and a 4" flare to couple with 4" pvc.
My second project is going to be a vented box. I don't have very good woodworking skills, so this is going to be trial and error. Depending on difficulty, I might even try the sealed box idea from Jon.
Christian
Christian
