Chris Tsutsui
- Feb 1, 2002
I have 3 sofas, 4 Aura Pro shakers, and a single 120 Watt AMP stable at 4 ohms. (Parts Express $100 model)
All of this to work with, and some wires.
What I tried at first was to use 2 bass shakers wired in parallel to = 2 ohms, then I series wired that those two with a single 4 ohm shaker in an attempt to get 6 ohms total.
What ended up is the first (series wired) shaker doesn't play anything, but the two parallel wired shakers shake plenty.
Now do you think I blew out the first shaker because of the bad wiring? Or does it not play because the way it is wired...
Or should I try 4 shakers and just put two shakers on the middle couch. Hook up 2 parallel, and the other two parallel, and then hook up those pairs in series to yield 4 ohms.
Or should I just wire the 3 bass shakers in series so that it's 12 ohms...
Thanks...
Thanks...
