Jason->D
- Jul 7, 2005
so after moving my receiver for like the 2nd time i've come to the realization that screwing speaker wire into the back is a pain. So I'm in the search for some quality banana's which don't like totally bad. My findings so far are....(oh yah price is important )
Atlona's
http://cgi.ebay.ca/10-PAIR-ATLONA-AU...QQcmdZViewItem
GLS Audio
http://cgi.ebay.com/40-Banana-Cable-...cm dZViewItem
GLS Audio 2
http://cgi.ebay.com/20-Locking-Banan...cm dZViewItem
(also if i where to go with GLS what is the major difference between 1 and 2?)
Dayton's
http://www.partsexpress.com/pe/showd...umber=091-1260
also if anyone else has some good budget banana's about the same style that would be available in canada (will buy online if needed) that would be great
Atlona's
GLS Audio
GLS Audio 2
Dayton's
