Jason Trich
- Oct 30, 2002
I have 4 surrounds but only a 5 channel amp, is it worth the upgrade to 7.1 receiver to utilize these extra speaks?
I just want some louder backfill.While I suppose a 7-channel amp would go louder, I don't think "loudness" is any reason to go 6.1/7.1. Simply increase the levels of your rear speakers if you're not getting sufficiently "loud" backfill.
What you should ask yourself is whether you're getting good imaging in the rear from your surround speakers, because it's the placement of sounds that's key here. Specifically, do sounds appear to come from directly behind you when appropriate? Do sounds that pan from rear right to rear left do so smoothly and without "leaping gaps" from one channel to another? If not, then you may have speaker placement problems, and some experimentation with placement (and height, as it effects dispersion) may be in order. On the other hand, your room may be such that you simply can't achieve sufficiently good imaging with only two surround speakers, in which case an extra pair of rear speakers and 6.1/7.1 processing might be the answer.
