Anyone used a riser as sub enclosure?
Discussion in 'Archived Threads 2001-2004' started by Dave Milne, Nov 8, 2001.
  1. Dave Milne
    Dave Milne Supporting Actor
    Jul 2, 2001
    I'm thinking of building a sturdy riser for my second row of theater seats and using it as a sub. I would imagine that 1" MDF, thoroughly braced, will be structurally fine for this 300-liter enclosure (approx. 60"x50"x6" internal). But will the long, flat box cause any resonance or tuning problems??
  2. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    I wouldn't think it would be a problem, as long as it is heavily braced. Wide spans of MDF, even at 1" thick, can vibrate.
    As far as resonance goes, 60" is about the wavelength of 180Hz. So, as long as you cross over lower than that, you should be fine... besides, with all that bracing, you would be breaking up the space.
    Sounds pretty cool.
  3. brentl
    brentl Cinematographer
    May 7, 1999
    GREAT idea Dave, but which way were planning o firing the driver??
    I'd guess you riser wouldn't be 15" high??? or would it??
    Mind you you'd need a 6" depth any way you look at it.
    Brent L
    OK guys ..... The tour of the Paradigm
    plant is now being planned. GO TO THE HOME THEaTER
    MEETS PAGE and register.
