anyone know the html code for... (1 Viewer)
Sam E. Torres
i want to know if there is a javascript or something for something on my website. i have a series of pictures, and i would like to know if its possible for text to appear under the thumbnails in a blank white area, when the mouse goes over the pictures. i want to use this so that i can put descriptions of the pictures. if you need me to elaborate, or don't really understand, just ask more questions. here's my website(go to pictures) http://hometown.aol.com/[email protected]
Ricky Hustle
Sam,
Try to get your hands on Macromedia's Fireworks program. Using this tool, you can easily accomplish what you need to do.
Ross Williams
Try finding it at: http://htmlgoodies.com/
It's the best Html / Javascript site I've found yet. Good luck!
"You know, there's a million fine looking women in the world, dude. But they
don't all bring you lasagna at work. Most of 'em just cheat on you." - Silent Bob
"No matter where you go, there you are." - Buckaroo Bonzai
Optimus Prime Films
Sam E. Torres
i use htmlgoodies.com and yes it is really good...i don't like to use programs though, i do my html on notepad.
[email protected]
DaveF
Catfisch Cinema
Dave
Sam,
There are various ways to do it, but I think the easiest is to use a style-sheet (CSS). The following should do the trick. Just copy and paste into a new html file, and change the link reference, image name, and text label to suit your purposes.
Code:
   Example File - Hover Link
A {
   background-color : White;
   color : White;
A:HOVER {
   color : Black;
   [URL="index.html"]
Graphic Description Text[/URL]
If I may be so bold, I recommend looking at some of the excellent HTML editors. Notepad is a poor excuse for a text editor, much less a HTML editor. Check out Arachnophilia (freeware, http://www.arachnoid.com/arachnophilia/index.html),
Larsenv
