Leo_P
- May 13, 2002
If so, are you using the 12v trigger?
I can't for the life of me get it to work. The amp seems easy enough to set up, you just set the switch on the back to on. Then I go to the Anthem's set-up menu and enable "All Triggers", then put an asterisk where it says "Power ON" and "Main" for trigger 1. Am I doing something wrong?
It's a pain to turn the amp on & off by hand, especially when I can control everything else (except my Xbox) from the couch. Help me out.
BTW, before some smartass (like myself:b) chimes in, I AM using a cable between the 2 components.
