I still have my Pioneer SA 8100 integrated amp and TX 7100 tuner (circa mid 70's IIRC) in my basement workshop. They still work flawlessly right down to the sexy blue lights on the tuner. That tuner will pull in stations my Denon won't even begin to tune in. Back in those days tuners were just that, tuners. I think most manufacturers today throw in the cheapest ones they can find because they figure most don't listen to radio on a HT system. Kinda wish I never sold my Soundcraftsman equalizer, that thing was a beaut!
im going out on a limb here, and say the oringal ones were replaced with those....I have a marantz 2280 and they are nothing like that. btw my 2280 is for sale if anyone out there is interested....
I have an old, mid 70's Sansui receiver somewhere in the attic. While not solid state, I do own one of these Transcriptor turntables however mine has a straight arm.
Earlier this year I acquired a mint condition SAE 2400 that was part of a large collection. I refurbished the unit and replaced all electrolytic caps, transistors and diodes on the output protection board, and old nickel RCA jacks and output binding posts with new gold plated ones.
I've been buying and getting tons of vintage audio gear. I just cant stop! most of them are from swap meets/pawn shops/goodwill/salvation army. I'm mostly a Sansui fan. But have a whole bunch of different items from Pioneer SPEC, Kyocera, Sony ESPRIT, Sony V-Fets, ESOTEC...
I have a Marantz 2225 for my bedroom system that has very similar clips. I also have a 2270 that I haven't looked at in quite a while, but I seem to remember the clips were even worse.
After I upgrade my HT system this peice will be the center peice to a seconary stereo system that will be for listening to CD's and LP's. I will ether track down the matching power amp or maybe look for anything that will work and perform as well.
Cool thread. I thought I'd use this opportunity to find out more about a Marantz Model-19 Stereophonic Receiver my dad handed down to me. I've been playing around with it a little bit, and it works great. However, I'm not savvy enough with electronics to attempt a restoration. Sure is fun to play with though, and it looks great with the wooden frame and blue backlighting. The only issues are the oscilliscope isn't functioning properly, and there is a bulb burned out behind the tuner dial. It could also stand a thorough cleaning, and perhaps some replacement parts, but it's still putting out quality sound. Can anyone tell me a little more about this machine? I do know it is circa 1972 and retailed for $1000 back then which is pretty amazing. Hard to find more info about it though. I'm interested to know if it is considered a collectors item, and if it might be worth trying to fully restore it. In the meantime, I'll continue to enjoy having it out on display and using it for a 2-channel music system!
Here is some information I came across on that Marantz reciever. The web page says its rare but I couldn't tell you if its a collectors item or nnot. If it is in mint condition I would say that if it isn't it will be soon enough.
Marantz Model 19 Receiver
Retail Price $1000.00 First Year 1970 Last Year 1975 Wood Case WC-9 Gold Face: Yes Channels: 2 FET Count: 10 Transistor Count: 66 Diode Count: 70 Speaker Connections: Two sets Weight: 46lbs
Amplifier RMS Power Per Channel: 50 @ 8 or 4 ohms, 30 @ 16 ohms Total Harmonic Distortion (THD): 0.15% Power Bandwidth: 20 hz to 20 khz Frequency Response: +0, -3db, 8hz to 80kz, +-0.5db, 20-20hz Intermodulation Distortion (IM): 0.15% or less
FM Tuner Gyro Tuning: Yes RF Sensitivity: 1.7 uV Ultimate Quieting: 73 db @ 50 uV THD, Mono 0.15% THD, Stereo 0.15% Capture Ratio 2.5 dB IF Image Rejection 85 dB IF Rejection: 100 dB at both IF and 1/2 IF
Preamp Multiple Bass Adjustments: +-15db @50hz Multiple Treble Adjustments: +-15db @12kz High Filter: 12db/octive @7kz Low Filter: 12db/octive @70hz Signal to Noise Ratio: -80 dB at the aux input Hum and Noise: -74 db @ phono input
