Any opinions on the toshiba 50h71 ?
Discussion in 'Archived Threads 2001-2004' started by anthony_b, Nov 29, 2001.
  1. anthony_b
    anthony_b Screenwriter
    Aug 18, 2000
    1,078
    3
    Any opinions on the toshiba 50h71 ?..thanks in advance.
  2. anthony_b
    Aug 18, 2000
    1,078
    3
    I'm thinking of purchasing this 50' inch set or the new Panny 51. Which brand should I go with ?
  3. anthony_b
    Aug 18, 2000
    1,078
    3
    well, I'm assuming know one has even bothered purchasing this toshiba unit. Plus I'm hearing so many problems with toshiba that I might just get the Panny. Thanks anyway.
  4. BradZ
    BradZ Stunt Coordinator
    Feb 19, 2001
    162
    try the toshiba forum on www.hometheaterspot.com for more info on this set. It's very nice and highly regarded save for a few issues. The new sony sets are getting alot of raves lately as well.
    as for the panny- I've heard that they're great after being fully tweaked and ISF'd. The only problem I have with the panny is the just mode is terrible for stretching NTSC programming. Tosh and Sony have much better modes for viewing 4:3 material in my opinion.
    check out the spot for boards and info on all brands.
    good luck.
    PS- you really need to be more patient. someone will eventually answer your post if you don't wait by the computer.
  5. CaspianM
    CaspianM Stunt Coordinator
    Oct 4, 2000
    90
    Based on my own experience with Toshiba xxH71, I would go with the Toshiba.
    It is a good set for the money.
    You might want to do a search here under both the Panny and Toshiba. You should find some useful info.
