Robert Hutchison
- Aug 19, 2001
It is my understanding that many viewers that wish to receive an OTA digital signal may need to use an outdoor antenna where right now one is not needed for an analog signal. In reading The Telecommunications of 1996 I see a section that prohibits restrictions that impair the installation, maintenance or use use of antennas used to receive video programming. This rule is cited as 47 C.F.R. Section1.4000.
Am I right in assuming that this means that any covenant or restriction about the installation of an outside antenna or 1 meter satellite dish by a local home owners association is now moot? The FCC fact sheet explains the limitations of the ruling regarding dish size and height above the roof line for the antenna, but if I'm reading this right, if you need an antenna for decent reception be it analog or digital you can put one up and no one can stop you. Has anyone had any experience wit this ruling? The FCC Fact sheet is located at http://www.fcc.gov/csb/facts/otard.html
