almost skiing time ? purchase snowsuit
Discussion in 'Archived Threads 2001-2004' started by DarrinH, Sep 19, 2001.
  1. DarrinH
    DarrinH Second Unit
    Aug 28, 2000
    301
    Any other skiers out there? My wife needs a snowsuit and I have been looking online for one without much luck. Can anyone suggest a place online? My wife could fit into a junior size suit so if you have any links for those post them as well.
    I've got to try to think of something else other than the US tragedy its starting to get to me.
    The EC
    The Entertainment Cave
    "Remember, if you can't be polite to our guest you have to sit at the kiddies table."
  2. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    32
    Pittsfield, MA
    Jay
    have you tried REI/REI-Outlet, I say this cause REI-Outlet is having a coupon right now for 20% off clothing:
    http://www.dailyedeals.com/free_onli...rei_outlet.htm
    Can't use it at REI though, just REI-outlet. You might want to see if they have any skiing gear cause they are the outlet side of REI but you can get cheap gear from them.
    www.sierratradingpost.com
    is another one that sometimes has inexpensive gear but they're not going to have as big a selection.
    Good luck,
    Jay
    HUGBEES! My Equipment List
    Rider in the 2001 Alaska AIDS Vaccine Ride
    Wanna help?
  3. DarrinH
    DarrinH Second Unit
    Aug 28, 2000
    301
    Thanks Jay, no luck. I guess I should have specified that this needs to be a one piece suit.
    The EC
  4. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    Make sure you get mittens with long strings .... I hate losing 1 glove becasue mom always tells me to come inside [​IMG]
    LL cool B
