air line pilots union pushing to arm US pilots
Discussion in 'Archived Threads 2001-2004' started by Philip_G, Sep 26, 2001.
  1. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    anybody read that article?
    basically ALPA is pushing for a voluntary program to arm commercial pilots, training would be similar to the air marshal training, and the pilot would actually have limited marshal authority. I'm sure there would be limitations like, ya can't go back into the passenger cabin to have a shoot out or something, but still it's an interesting idea.
    I'm curious what people think about it. On the heels of the proposal is the ATC recording of the pilots of one of the flights getting sliced up, so that will probably influence people's thoughts. But I think it's interesting, 3 weeks ago I would have thought you wer eout of your mind to suggest alpa would propose this.
    I'll get the ball rolling, personally I'd volunteer, I don't really see a downside with a voluntary system, air force pilots fly with a side arm pretty often, if you're comfortable with firearms (as I am) then I don't see the problem.
    ALso, I see it as a nice solution to the air rage problem, I don't think a crazed PAX is going to rush the cockpit if he knows they may be armed and shoot him/her.
    as I understand (but don't really know) it works this way for ships, often times the captain is armed..
    Oh also.. an afterthought.
    people are going to assume an airplane will rip apart in mid air or something like in the movies if a bullet goes through the fuselage, which isn't the case. There are rounds that could be used that would not penetrate metal, and if they did a half inch hole isn't going to jepordize the airplane. Pressurization systems can easily cope with that small of a leak (the outflow valves that control the pressure are something like a foot in diameter)and the structure can handle the hole. There's some maintenance people here, they can shed some light on that I bet [​IMG]
    [Edited last by Philip_G on September 26, 2001 at 09:31 AM]
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,644
    418
    The only drawback is terrorist impersonating an airline pilot, and would be wielding a gun in the cockpit...
    I guess we'll need fingerprint/retina scan ID system to make sure the pilots onboard are the actual pilots, and to be allow access into the cockpit. Who knows how security measures on airplanes will get to be.
    PatCave; HT Pix; Gear; DIY Mains; DIY CC; Sunosub I + II + III; DVDs; LDs
  3. Deane Johnson
    Deane Johnson Supporting Actor
    Jan 27, 1999
    524
    I think Patrick has hit part of the issue right on the head. Some of these guys came on disguised as pilots. If guns were permitted for pilots, they would have come on armed with guns with no one questioning it. I certainly have no problem with the pilots blowing these guys away before they can do harm, but there are certainly some side issues that need to be addressed.
    It seems to me there is also another issue and that is the practice of letting dead-heading pilots sit up front. If the cockpit is reinforced and locked as proposed, it will do little good if the terrorist is invited in and given a seat and a cup of coffee.
    It seems to me there needs to be some major policy changes in this regard.
    Deane
    [Edited last by Deane Johnson on September 26, 2001 at 10:16 AM]
  4. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    What about the Tazer(sp) idea??
    A gun can go through the hull, but a stun gun can't.
    I think a gun for the pilots is the last resort.
    LL cool B
  5. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    32
    Pittsfield, MA
    Jay
    Would the pilots be willing and able to use them? And what if they get killed in the process and the hijackers or nobody on board has a clue how to fly? Anybody with a knife can take a hostage and demand the gun from the pilot. The pilot is going to have to be willing to either shoot the hostage taker, collateral damage to other passengers or hostages be dammed, or hope that either the hostage taker is chicken or another passenger jumps the hostage taker.
    The idea about assuming everybody behind the door is dead is proabably a good idea, but how good is that in practice, do you think that would work with the American public?
    Jay
    HUGBEES! My Equipment List
    Rider in the 2001 Alaska AIDS Vaccine Ride
    Wanna help?
  6. Deane Johnson
    Jan 27, 1999
    524
    The Tazer probably deserves investigation. Maybe for all flight crew members.
    On the issue of bullets piercing the hull, I believe they use some special type that doesn't do that, but rather flatten out and mess up a human body a bit. Obviously, they aren't as effective as a regular bullet, but better than nothing. It's my understanding that Sky Marshalls already use these.
    Deane
  7. MickeS
    MickeS Producer
    Jul 24, 2000
    5,058
    Bad idea. The pilots should fly the plane, period. Get an air marshal on board or arm the flight attendants, but make the pilot just fly the plane.
    /Mike
  8. Ryan Wright
    Ryan Wright Screenwriter
    Jul 30, 2000
    1,875
  9. Deane Johnson
    Jan 27, 1999
    524
    Probably at this point in time, anyone hijacking an airliner is doing so do great harm with it. That means that if the hijacking is successful, all passengers will be killed within a short time. It's probably worth some risk to one or two people in order to save the rest of the passengers, and likely hundreds to thousands on the ground.
    Look what the brave passengers on the PA flight did without much of anything to work with except their determination to prevent further blood shed.
    Horrible thoughts, but this is where we are now.
    Deane
  10. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
  11. Richard Kim
    Richard Kim Producer
    Jan 29, 2001
    4,385
    I believe that there have been reports of arrests of suspected terrorists trying to board planes as pilots.
    Because of this risk, we should not arm pilots and instead have sky marshalls, and install metal doors for the cockpit.
  12. Tom-G
    Tom-G Screenwriter
    Mar 31, 2000
    1,638
    2
    I like the idea of sealing off the cockpit so that there is no entry from the seating area. Arming the pilots would surely be helpful, but that isn't the most feasible way of preventing a hijacking.
    Is there any reason why the pilot would need to leave the cockpit? I can't think of a good reason, so why not seal off that area?
    As for the bad rap about the characters--hey, I've seen space operas that put their emphasis on human personalities and relationships. They're called "Star Trek" movies. Give me transparent underwater cities and vast hollow senatorial spheres any day. --Roger Ebert on The Phantom Menace
  13. PatrickM
    PatrickM Screenwriter
    Aug 10, 2000
    1,138
    I'm not sure arming pilots is a good idea. You have to be able to use it properly to be effective. Their pilots first not security personnel or law enforcement.
    Isn't there a stat that says 70% of people who have guns in their houses who are broken into have their own gun used against them?
    Patrick
    My DVD Collection
  14. Jeff Ulmer
    Jeff Ulmer Producer
    Aug 23, 1998
    5,584
    Who is to say that there aren't already terrorists who hold pilot licenses that just haven't been called into service? Now you want to allow weapons on board the plane that could either be used by a terrorist or be captured by one. Bad idea. Lock the door and be done with it, and make sure ground security is tighter. Use a sky marshall if necessary (create some jobs).
    I doubt we will ever see a hijacking like this again, as everyone knows the plane could possibly be used as a weapon, and those on board will know it, and can react accordingly.
    Zardoz Online | Burt Lancaster is The Swimmer | dOc
  15. Jay Taylor
    Jay Taylor Supporting Actor
    Sep 8, 2000
    830
    Oklahoma City
    I’m in favor of arming the pilots but I would want a better method of identifying them as actual pilots to insure they are not imposters. I also would want them to not unlock the door for virtually any emergency in the back or a hijacker would use that weakness to get the pilot out of the cockpit with a diversion.
    I think most people agree that the pilots should have arrest authority but if they are locked in the cockpit that authority may never be used. Since the stewards, stewardesses, and passengers will be left to deal with any problem in the back, perhaps we ought to give some arrest authority to the entire crew, not just the pilots.
    Jay Taylor
  16. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    I think that identification is already an issue.
    in the past it was sort of a professional courtesy to allow any pilot from any airline to jumpseat, it could be a vacation, or a guy going to work. I did hear that report yesterday that one of the terrorists was wearing a pilots uniform and had been permitted to jumpseat. No one's jumpseating right now last I heard (pissing off my friends that had 2 weeks off and wanted to get out of town haha)
    Identification is a problem for air marshals too, I don't see any differentiation between them and an armed pilot, other than a marshal would be easier to impersonate as they have no uniform.
    the problem I DO have with a marshal, all the terrorists in theory have to do is team up, have one stand up and do something to draw attention from the marshal and another come in and kill him. Really, it wouldn't be hard I don't think. Not to mention the "spottiness" of an air marshal, how many do we have? a couple thousand for how many thousands of flights a day?
    I think a lot of pilots may not like guns, making them apprehensive to use the force when it's needed, that's why I think a voluntary plan is a good idea. Personally if my life or the life of my crew or passengers was at risk I'd have no problems. But you don't know until you're in that situation.
    interesting discussion though, wanted to see if americans could accept the idea, I didn't think we would..
    it's like the old saying
    "the government can only do for you what the government can do to you"
  17. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    can't seal the cockpit completely, pilots have to pee too [​IMG]
    really though, if a terrorist is killing your crew, are you going to site there behind a locked door and not help? Are secure doors a help then?
    I think a lot of you are over estimating the amount of attention required when an airplane is in cruise, sure there's stuff to do to prepare ahead, but really it's just pushin buttons and monitoring it. takeoff, climb, decent and approach/landing would be a little different.
    [Edited last by Philip_G on September 26, 2001 at 12:07 PM]
  18. AjayM
    AjayM Screenwriter
    Aug 22, 2000
    1,224
    Arming pilots is a knee-jerk solution to a big problem. You can't just drop a gun in the cockpit and tell the pilot to "shoot the bad guys". If you've ever fired a gun before you'd realize that it's a little harder than what they do in the movies, now add in a small room like a cockpit, the huge adreniline load, etc and you have a problem. There's a reason why anti-terrorist group like the FBI HRT (Hostage Rescue Team) train every day for the few times they need to be deployed. Nevermind trying to keep the plane flying. So now you'll have to train the pilots at a top level CQ combat, and make sure they're still qualified to fly the plane.
    And we won't go into the whole problem of bullets and electronics don't mix, or bullets through the skin of a plane don't mix, etc.
    Sealing off the cockpit and instructing the pilot to never open the door is a much better solution. With instructions that if any problem arises that the pilot lands the plane at the nearest airport that is capable of landing the plane, when you're flying over the US you're probably never more than 10 minutes of flying time to an airport. It's not that much different than the scene in Air Force One when the terrorists start shooting and the first thing the pilots do is lock the door and go for an emergency landing.
    {Joke}Of course if you really want to solve the problem, instead of handing out the newspaper when getting on a plane hand out handguns to all the passengers. If somebody stands up and declares he's taking over the plane, he now has 100+ armed and now very angry armed people who won't hear of it! This also solves the security issues, no need for security, no need to smuggle weapons on-board, etc....problem solved [​IMG]{/joke}
    Andrew
  19. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    I take offense to "just dropping a gun in the cockpit" as that's far from what is proposed, if we're talking the same training that air marshals receive, are you saying they're a bad idea also?
  20. Jin E
    Jin E Second Unit
    Nov 19, 2000
    452
