ACI has at least 4 or 5 suitable stands from about $100-$300. I had a set of the Atlantis $175 stands with my Sapphires. A good combination visually and sonically. Whatever stand you get, make sure to fill with something heavy like dried sand or steel shot. I believe you need a stand about 24-25" tall for the Sapphires.
I visited the ACI site and did look at what they had. Are the stands heavy and well built? The price seams reasonable. Do you know anything about the Sound Anchor stands - a little more pricey, I think?
Greg, the stands I had under my Sapphires were from Atlantis, they were called Match. They weren't particularly heavy until I filled them with sand. Just about all stands need to be filled with sand or steel shot or a combination. The Match were well made and looked and worked well. I know ACI also has stands by Sanus. The Soundanchor stands I've seen have been well built. I believe you can order directly from soundanchors.com
Thanks to you all for the valuable input. I nailed it down to the Sound Anchors or the Osiris. The Osiris looks nice and it appears to be built like a tank, plus it's cheaper. I'm going to see the Sound Anchors tonight at Audio Consultants.
